Root - RK3188 - CS918 - Android TV Box
    Hi Friends,
    I am very new to this. I have purchased below box RK3188 Model CS918
    http://******.en.alibaba.com/product...pe_camera.html
    I would like to mainly use this for XBMC. And would like to directly start XBMC when I start the device.
    However, I need to know the below.
    1. how to root this device?
    2. Which custom ROM is best and fast specially for XBMC which is compatible with this device?
    3. Also how to flash custom ROM on this device?
    Any help would be appreciated.
    Chirag
    Hi and welcome,
    I checked-out the website.. and on the site it says your unit has bluetooth..
    Well..
    A real CS918 has no bluetooth
    So, you unit is a T-r42
    Now there are about 9 versions/revisions of this units/pcb
    -this means you need to open-up the device.. to see what pcb/motherboard you have
    See (this site as reference)
    Hi Guys: The reason i write this post is we are seeing so much questions, and problems which customer are faced for the following device: Well, this photo is coming […]
    Only after knowing what pcb.. you have.. can you look for a compatible custom firmware
    Ps
    Under the rubber pads on your tr42 are screws.. for opening you box
    Ps2
    Root:
    Install moborobo on you pc then quit the app / connect pc to tr42 / use TPSarky to root your unit
    Ps3
    On blog.geekbuying.com is a manual on how to flash/firmware update your unit
    Goodluck
      XT-Q7-V10
      See below with quotes
        Originally posted by mitchell4you View Post
        Hi and welcome,
        Well..
        Ps
        Ps2
        Root:
        Ps3
        Goodluck
        I did open the box and it turned out to be XT-Q7-V10.
        Please see the attached picture.
        Is there any custom rom available for this combination and are steps to root this device still the same?
        I was looking specifically something for XBMC.
        I have recently received updated STOCK ROM for this device by the vendor. Can anyone advise how to create custom rom from this?
          Sadly no custom rom (yet)
          The rooting is still the same.. note on youtube are also vids
          The best xbmc versions in my opinion for rk3188
          SPMC (http://ouyaforum.com/showthread.php?8220-SPMC-Koying
          And
          BeyondXBMC (search freaktab)
          If seek knowledge about creating a custom rom..
          -see freaktab developer section
          Ps..
          Could you post your updated/firmware? (to help others.. incl developers)
          Goodluck
            Root cs918
            Is there anyway I can check what model I have without opening up the device?
              then, for root is the same method for four models???
              ZTE BLADE S6
              R-BOX PRO 3GB RAM
              M8S RK3288
