Pipo M9 Pro HDMI
    Pipo M9 Pro HDMI
    Hi Guys
    I can not seem to get ay HDMI output on my M9 pro using Belkin adapter mini HDMI to normal size is there something else I should be doing
    Originally posted by lagoslads View Post
    Hi Guys
    Are you on stock ROM or using custom ROM? Have to enabled the HDMI option in settings and selected a supported resolution?
      I am using the new Riley rom and have tried all he resolutions but to be fair it was not working before not sure if the adaptor is compatible
        Have you tried another adapter? For Pipo devices its better to use "cheap" common cables.
        Brand adapter like the one you are using sometimes can't go deep enough to stablish a good working connection.
        I bought one of those generic mini HDMI to HDMI and it works just fine with both my M9P and M7P.
        Maybe your problem is similar to this:
          Yeah, I have also got a cheap cable which works fine on my M6 Pro..
            Same here, got a cheap hdmi cable. Works excellent with my Pipo M9 Pro RileyROM 2.6 Kitkat!
            This is the one I bought:
            **** Link
              Hi Guys
              not plugged in far enough.... cut back the sheath on the HDMI lead/adapter, so it sits further in the port
                Thanks Guys
                cut down adapter and its working fine I am using RileyROM 2.6 KitKat but still have very poor Wi-Fi reception looked on internet for fixes tried the two wire method but still not much better is there an after market Ariel
                I can replace the original with as its only a tiny one would a bigger one say from a laptop work /
