Problem with using mouse or keyboard with QX1.
    Hey guys. My first post here on this forum.
    I have a imito QX1 with the following keyboard:
    http://i.****img.com/00/s/NjAwWDYwMA==/z/2kMAAOxy63FSuTGU/$_12.JPG
    It works so-so to say the least. At times it works and at other times I want to break iit nto a thousand pieces.
    I tried 2 different wireless mouses in the OTG USB slot on the QX1 but they don't work. Anyone knows why? I'm on stock 4.2.2 ROM.
    Now I'm considering buying a Logitech K400 but what if it doesn't work with the QX1. Any ideas?
    What do you guys use to remote control the QX1? I tried to find server-client remote mouse apps but they require root.
    I've used the K400 and it was fine but I was also on the Quickshot v2 ROM as well as leolas's v1.5a ROM ... I didn't try them on the stock ROM.
    I would suggest using an external wi-fi antenna and/or a USB extension cable so you don't have any interference on either.
      Bought the Logitech K400, works just fine on stock ROM 4.2.2.
