Anyone has any clue or own experience?
PIPO M9 Pro Camera Bad Focussing
I did not buy my Pipo for the camera, but I have seen good, sharp pics from reviews, so I was very disappointed with my unit. Autofocus apparently works per se, but the sharpest postion reached is VERY unsharp. I guess it can be a hardware problem with the lens or the lens position?
Anyone has any clue or own experience? -
Camera on M9
What Android are you running ?
I run the latest RileyROM 2.6 KitKat and have no issue with the camera or autofocus at all. All photos are clear, even the panorama ones.
One can not ignore the possibility of hardware failure...
As I don't know which version you you you may want to try the above
(see http://www.freaktab.com/showthread.p...692#post156692) for further info.
/Kastrup
Originally posted by bjom View PostI did not buy my Pipo for the camera, but I have seen good, sharp pics from reviews, so I was very disappointed with my unit. Autofocus apparently works per se, but the sharpest postion reached is VERY unsharp. I guess it can be a hardware problem with the lens or the lens position?
Originally posted by Kastrup View PostWhat Android are you running ?
/Kastrup
Camera M9Pro
I can't remember how the camera was with the stock Rom as I re-flashed it the day after I got it.
My latest advice stands, otherwise you should contact your sales point or the factory.
/Kastrup
Originally posted by bjom View PostI am running the 4.2.2 out of the box. When you say your photos look good, it makes me even more think I have a hardware problem. If that is the case, what can you do? Does anyone ever managed to fix a bad focus problem?
Originally posted by Kastrup View PostI can't remember how the camera was with the stock Rom as I re-flashed it the day after I got it.
/Kastrup
Anyway, I did what I should have done long ago. I tried to flex the back cover, with attached lens, by gently pressing with my fingers. The effect was immediate, I could see focus shifting, as I applied and released pressure. Focus did not get perfect (I dared not press too hard), but good enough to make it worthwile pressing the shutter to check out the result. Not perfect, but dramatically better.
So, it is clear there is a problem with lens position. The question now is what to do about it. Should I try to make a permanent indentation on the metal back (hoping not to permanently ruin the unit)? Should I open it and see if the lens unit can be moved somehow less drastically?
Suggestions, anyone?
There are currently 3434 users online. 0 members and 3434 guests.
