MK908ii stability problem
    Hello,
    I am having really big problems with my mk908ii tv box that I bought from geekbuying.com
    The problem is that the device is very often restarting and applications are crushing all the time. I have tried so far changing power supply of 2 amps, I tried reinstalling many ROMs;
    * Stock ROM 4.2.2 (okay this sucks)
    * Finless 1.5a (this one worked the best, but still restarting a lot and apps crashing)
    * KitKat Finless 2.0 beta (worse then 1.5a in terms of stability)
    * HFW 2.0.2 and 2.0.3 (could not start booting at all)
    * 4.4 kitkat beta 1 (very bad)
    I tried editing 1.5a vsync finless kernel by lowering frequency a little bit/boosting voltage, in my opinion that should provide stability.. but it didnt really..
    What is optimal input voltage for this device besides 2 amps of current?
    Does anyone have any solution?
    Regards.
    Have you change your power supply?
    Her stock power supply is often faulty
    I'm suggest you to change it for a good 2.5A or 3A, it's work well for mine.
    Bonjour! Je suis de Shawinigan, Québec, Canada
      Thank you.
