Tvheadend compiled for Allwinner A31 kernel 3.3.0 for android
    must be rooted, copy dvb files to data folder
    open terminal write command or add init d later copy system/etc/init.d for auto start
    compile your usb stic tuner
    Pls test it. Later report work or not
    The file for android. This file no damaged that for 7zip unpack
      I compiled for abdroid with 3.3.0 kernel. Allwinner a31 tvheadend.zip
        Give me link for your kernel for A3s. May be work a31 compiled tvheadend. can you tryed this
          Oh ok, I need a compile for A31S
          Any update on this?
            no find kernel A30 that where is it
              I still can't figure how to use this..
