GBox Midnight MX3
    GBox Midnight MX3
    I would also like to know if there is a custom rom for the Gbox midnight.
    Thanks in advance.
    what type of rom you need? linux?
      Thanks in advance.
      Right now I'm using the community build STTV Linux Build Release 4 (version 5 have a problem resetting settings occasionally so don't use it) and it is super fast and XBMC works like a dream. It have put new life and made the Midnight box a great XBMC box when it almost was dead and unusable to do Matricom abandoning it with an Android release that wasn't working. STTV Rom Q&A and Download page on Matricom forum http://matricom.net/forum/index.php?topic=2733.0
      The only thing is that since it is an XBMC only (Linux just built for XBMC) you loose the ability to add Android Apps (Netflix, vGet, etc.) so you will need another device to do that. Like I said, the Linux build works like a charm, and flawless with all add-ons like Project Free TV, Movie25, One Click Watch, Icefilms, 1 Channel, etc.
        what i use is j1nx
          Sorry guys for the late reply .. unfortunately i am using android version reason for this is Linux you can only use for the XBMC but i wanted to use other android apps as well ..
          Is there i can able to get a custom rom ? other problem i have is the flash player currently installed version 10.2 and can't install new version
          Pls help ?
            I tried Finless 1.4 ROM but wasn't unsuccessful in running it (see Bob's explanation about why and what can be done to make it work on G-box Midnight - http://www.freaktab.com/showthread.p...inless-ROM-1-4).
            Maybe someday a good Android rom with Kit Kat or some tweaks will become available for the MX, until then, I will run STTV Linux XBMC on it since it works fine.
              Thanks soshowme by the looks like 1.4 Rom is for M2 .. i have to wait and see my box used to be linux version and then changed it to android cos i can use for other things as well like skype web browsing etc, linux is v good but only for XMBC. I hope matricom will release something soon
                Which 1.4 are you talking about?
                One is for M6 device (My Jynxbox M6). M6 never was used by AML so it is called a MX. But you have to be careful when you say you have an MX as clock speed varies by manufacturer!
                The other 1.4 is for a M3 box I have. Again Jynxbox HD and mini.
                My Beta ROM work on my Pure Linux box (Again by Jynxbox and my Prometheus) and is a M2 proc.
                  My Beta ROM work on my Pure Linux box (Again by Jynxbox) and is a M1 proc.
                  Hi Bob
                  I thought ur 1.4 works for M2, if it works for gbox midnight i will upgrade and see ..
                    Hi Bob
                    Yes sorry.... I typo'ed that and just corrected it before you quoted me. Sorry.
                      is that work for m2 only right ?
                        I do not know but I do not think so. Wrong kernel!
                          No worries thanks for your help Bob ...
