I bought Jesurun Mx Android tv player from dx. Here is link to product.
Some info from that box:
Jesurun MX Quad-Core Android 4.2.2 Google TV Player with 2GB RAM, 8GM ROM, Bluetooth
Chipset: RK3188
CPU: ARM cortex A9 quad core. some info tool told that cpu has only 1.4ghz. i really hope this isn't RK3188-t model. This was advertised as 1.6ghz and RK3188 model.
Wifi is probably AP6210
I had problems with video playback cause it didn't play smoothly any video, low or hd, without moving mouse. I have tried to fix that with different kernels but didn't find any that would fix that problem. Then i decided to try another firmware and that was bad decision. Now i haven't found single firmware that works with that player and of course i didn't backup my original firmware.
I was hoping if someone knows firmware that should work with that or have stock firmware for this one? I tried to find better info from this device but couldn't much usefull info from it. Added 16 images of the board if it helps. Some other devices seem to have android tv stick inside but this have totally custom board.
I would really appreciate any help i can get with my problem. I can try to provide additional info from this box if needed but this is pretty much all info i have at this moment.
Update 28.3.2014
I founded similar board from this thread and link to to firmware that can be found here. That version 2 firmware works with this device. This is newer firmware that came with this device but i still have video playback problems. Trying to solve that one next.
