Which ROM matches my uses - PIPO M6 PRO (Non 3G)
    Hi Chaps,
    Thanks Riley for all your work on the ROMS.
    I have the above mentioned Pipo M6 Pro (Non 3G) I am currently using the Jellybean rom.
    I use the Pipo on the tube - Playing the odd game, watching video and reading kindle/pdfs
    At Home I do internet surfing, video + streaming and a few apps mainly Yatse.
    Would I get a better experience upgrading to the KITKAT rom or shall I stay on the Jellybean?
    Cheers
    Zoot
    If you are happy with JB and you can do everything you like to do with it, stick with it.
    While my current KK ROM is completely stable on my tablet, results may vary.
    If you understand the process of switching back and forth between KK and JB...the only real answer is to try each...and you pick out what you like better.
    Randy
