HI726 Android tv Box
Hi, I am new on Android Tv Box so I need Help. I bought (http://www.tinydeal.com/hi-726-andro...-p-120356.html) from tiny deal, i installed xbmc, everything work fine but Icefilms HD are not smooth. I am including a sample on youtube. (https://www.youtube.com/watch?v=FzVtXFnR2G) PLS HELPTags: None
Originally posted by fsigns View PostHi, I am new on Android Tv Box so I need Help. I bought (http://www.tinydeal.com/hi-726-andro...-p-120356.html) from tiny deal, i installed xbmc, everything work fine but Icefilms HD are not smooth. I am including a sample on youtube. (https://www.youtube.com/watch?v=FzVtXFnR2G) PLS HELP
Your device is 1.0 Ghz instead of 1.6 Ghz and dual-core GPU instead of Quad-Core GPU.
XBMC will not play smooth.
You can try one of the Vidon.me XBMC versions and see it it works better.
Originally posted by TaajanA31S CPU are fine, only problem is bad deving on the manufactur. Use Beyond XMBC 3.3, its actually here in Freaktab just search for it. Also, you can add a heatsink to the device. I plan on doing the same but, I have not really had any problems with the over heating. Now when a custom rom comes out and all the true features are unlocked, then I may have to. Until its an awesome device.
There are currently 2938 users online. 0 members and 2938 guests.
