After a long journey, I received my pipo M9 Pro 3G device today and after charging it, I started to check the device and wanted to read the user manuel with built in E-Bok reader. But all of sudden, a notice appeared on the screen ,notifying " Unfortunatelly, PhotoGridWidget has stopped" and since than the device can not accept any other commands. Although I pushed the below "Ok" button to clear this notification, it neighter dissappeares nor allows to push any other button on the touch screen. I tried many times to restart the device and even re-set it , but the notifying problem still persists and I can not use the device any more, since I can not give any other touch commands on the display..
Pls. kindly inform, how I can resolve this problem, and if this can be handled anyhow, or whether the device can be set to factory settings, where I can not command any buttons on the screen?
I have android cell phone, Galaxy Note 2.. It allows to set factory settings by pushing some original (non virtual) buttons like on/off + voice + back in the same time..
Awaiting your soonest reply,
Best Regards
