Which ROM?
    Which ROM?
    Hi, i'm new to this whole android TV stuff!
    Ive bought a minix x7 and at the moment its just stock with beyondXBMC on it atm!
    So fairly general question, which rom should i flash?
    I basically bought it to what icefilms and sport if that has any reflection on the rom used?! Also could someone tell me how to get flash on it? i went onto the flash website and went through the archive but couldnt find the android version (its so i can use plus1hd to watch the football)
    Cheers!
    I'd suggest just reading the numerous threads that asked the exact same question... why start another when the info is already here
      ok took your advice decided to go with hardware guru. but do you have any idea with my flash problem?
        Go to this link. There is a flash for Android available to download and install.
        Vab
