Mounting NTFS HDD with samba on K-R42
Anyone done that? I have managed to setup samba on my previous android mini pc (mk808) it was developer edition of app (samba filesharing from xda-developer forum), with this k-r42 i could not set it up. I have tried mentioned app, but nothing is appearing in windows network, other app samba server from playstore not working with windows 7. Is there any other way to show this hdd in my network so i can stream files? Only i have succeded to mount it like ftp server, but in that case i can only copy files first to my pc and then play it. I would like to stream directly from hdd. Thanks in advance!Tags: None
Originally posted by gsavicic View PostAnyone done that? I have managed to setup samba on my previous android mini pc (mk808) it was developer edition of app (samba filesharing from xda-developer forum), with this k-r42 i could not set it up. I have tried mentioned app, but nothing is appearing in windows network, other app samba server from playstore not working with windows 7. Is there any other way to show this hdd in my network so i can stream files? Only i have succeded to mount it like ftp server, but in that case i can only copy files first to my pc and then play it. I would like to stream directly from hdd. Thanks in advance!
I have tried today mounting usb drive formatted in fat 32. App crashed after trying to enable it. I have followed instructions from xda. Unit is rooted, i have installed developer version, disabled smb.conf replacing, and i have manually replaced smb.conf file with this one:
# Auto-generated by com.funkyfresh.samba
# smb.conf last written on 2013-07-03_12-49-11 app build 111105d
# Manual edits of smb.conf are not supported.
# Sharing of non FAT based filesystems is unsupported. Do so at your own peril.
[global]
interfaces = wlan0 eth0
bind interfaces only = yes
workgroup = WORKGROUP
server string = Samba on Android
netbios name = MYANDROID
remote announce = 255.255.255.255
encrypt passwords = yes
security = USER
restrict anonymous = 1
load printers = no
printcap name = /dev/null
disable spoolss = yes
deadtime = 5
delete readonly = yes
nt acl support = no
inherit permissions = yes
socket options = SO_SNDBUF=16384 SO_RCVBUF=16384
local master = no
unix extensions = yes
[hdd1]
vfs objects = fake_perms
comment = Android /mnt/HDD
path = /mnt/usb_storage/USB_DISK0/
force user = root
read only = no
writable = yes
guest ok = yes
Path to the hdd is correct. That same procedure worked with no problems on mk808, but on this k-r42 app is allways crushing after enabling it, and i dont have hdd in network.
There are currently 2525 users online. 3 members and 2522 guests.
