Also what is the star symbol that is next to the power symbol it says favorites how do you add favorites to that
i have a question about Xbmc
When you are in the main menu of the Beyond Xbmc Xbmc media center you see right above the categories it says search then it says Movies TV shows Music videos how do you add TV shows and movies to that section.
Also what is the star symbol that is next to the power symbol it says favorites how do you add favorites to thatTags: None
Originally posted by cooltwou View PostWhen you are in the main menu of the Beyond Xbmc Xbmc media center you see right above the categories it says search then it says Movies TV shows Music videos how do you add TV shows and movies to that section.
The Star button next to the Power button is the favorites folder. You add things into it be selecting a series or a film for example and then pressing c on the keyboard or the settings button on the remote control to bring up the context menu and then selecting add to favorites.
To Infinity and Beyond.... XBMC
Originally posted by Flumpster View PostThe Movies/TV Shows/Music Videos next to the search should only have a number after each one telling you how many of each items you have in your library. If you do not have numbers next to them then you have not added any sources and added them to the library.
http://wiki.xbmc.org/index.php?title=Main_Page
That link has this section on favorites http://wiki.xbmc.org/index.php?title=Favourites.
But there is one thing missing it doesn't show how you go about getting the TV shows or movies to the favorites in the star beside it
Originally posted by cooltwou View PostThat link has this section on favorites http://wiki.xbmc.org/index.php?title=Favourites.
For adding things to the library for search to work etc start on this page. http://wiki.xbmc.org/index.php?title...ck_Start_GuideTo Infinity and Beyond.... XBMC
There are currently 2958 users online. 2 members and 2956 guests.
