Opening apps reboots dongle
    Hi guys,
    Just recently started getting this issue. Whenever I open an app it reboots my android tv stick.
    Could anyone shed some light?
    I have tried different ROMs and Firmwares but still have the same issue.
    Thanks in advance.
    Use a quality power supply that provides enough amperage, most quad core units need at least 2a... I usually recommend at least 3a or more output so there is more than enough power.
    If that doesn't correct it.. test with the latest factory ROM before you give up... everything else would indicate bad/failing hardware and that would mean you'd have to replace the device.
      Also make sure time and date are well set, sometimes when app try to update time give error...
      T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
