I have a Vcom dv111d, very likely it's a mk808 (non-b) clone.
I don't want to dissassemble it, because of warranty.
It's actually running android 4.1.1 (even though homepage says 4.2)
Power is fed through mini-USB.
Please recommend a rom for me to use:
- 1:1 pixel perfect 1080p is CRUCIAL!
- Performance is not important.
- The device is intended to run a simple webview app with local html5 files, so wifi isn't important either.
The current rom runs 720p
CPU rate control would be nice too, I don't want any overheating issues, 1 ghz would be perfect for the task the device will be intended for.
Thanks in advance!
