how do I turn on GPS?
    1st and most importantly, thank you Riley for all your hard work. I've been lurking for a while now and find this forum of great help.
    I have the M9 pro running 4.4.2. I thought it was JB but now I've confused myself. Either way I can't seem to be able to figure out how to turn on GPS. I can't find the switch in the settings. Any guidance would be appreciated.
    Thank you all...
    I thought I found it but google maps now tells me I don't have GPS hardware. How do I confirm this?
    Thanks again....
    I'm not sure, exactly, in the M9 Pro ROM...but for my M6 Pro, I had to click the button in the right notification bar to power on GPS. You may need to go into your location settings and activate those settings. It seems the default is for battery savings only.
    Then you can run the GPS test app or another GPS app and see what you get.
    BTW, I'm moving this thread to the main Pipo section...this sub-forum is only for ROM's.
    Randy
      Moved from Current Pipo ROM's sub forum.
      Randy
        Yep top right notification tab. It was the location icon. However, after that maps informed me I didn't have gas hardware. So I was hoping someone could point me in the right direction to finding out if this is true. It may be I just need to reflash a new rom. Is the 4.4.2 update KK? If so I'll roll back to check.
        Thx
