Does M6Pro factory KitKat firmware support multiple users
Originally posted by NickC_UK View PostHas anyone got the Pipo factory KitKat firmware installed. If so could you tell me if that has the multiuser tab available (underneath Apps tab)?
Thanksif you appreciate my efforts this is the link for any donation:
Re: Does M6Pro factory KitKat firmware support multiple users
Originally posted by giouncino View Postnot available on kitkat unless you install xposesd framework as far as I know.
Sent from my M6Pro using Tapatalk
Yeah, I did, and it works flawlessly.
It just does a soft reboot after adding a new user. Supose this is even the normal way it works.
from there on all works very well!
Switch over to the other user to set his/her settings.
Using it with riley 2.7.2 KK rom on m9pro.
PS, I also installed the privacy module.
You can find the framework here:
Use this forum to chat about xposed framework and modules to modify your device without flashing a custom ROM
install
in the framework download the multiuser module
then under modules, activate it
reboot
setup users
There are currently 1610 users online. 0 members and 1610 guests.
