It's very strange. The usb stick is ok or is boken? Please test it on another device/pc.
If the stick runs correctly look at this sequence:
1. Put the usb stick in the USB port and wait 10 seconds.
2. Arnova Unmout Usb Mass Storage (a circle on a status bar).
3. Go to setup and select "Wireless& Networks"
4. Go to "Mobile Networks"
5. Go to Access Point Names
6. Wait - After few seconds a list appear.
7. Select your APN
8. Back Home.
After few seconds "3G" icon appear.
This is only for the first time. In the next times all is automatic (the setup remain) and 3g appears after point 2.
Try with this sequence or say to me at what point you have problem.
Bye.
Jean-Luke
The 3g stick works perfectly on my pc and the Arnova USB port with a usb keyboard.
So this is a stupid question (which it really IS NOT) DO I HAVE TO PUT THE 3G STICK IN THE MICROUSB?!?!? That doesn´t make any sense to me... But I´ve read that on Arnova 10B G2 you have to use
the microusb slot for 3g with some usb A - usb microB host cable, that I cannot find from Finland... BUT on the Arnova site
it is said that "all you need is to slip a data sim card into the stick, plug it in".
So the 3G stick isn´t flashing any lights, so no power? but why? Has anyone else had this problem?
Is this with the stock rom or one of Bob's?
I can't remember if I tried my Archos 3g stick with the stock rom (and don't really want to flash that back again!). The only rom of Bob's I know it works on is 1.5D.
Which stock ROM? If it is the 10G2 "philly" edition then this kernel is known to not support any 3G sticks!
Only the orginal 10 G2 "non-philly" ROM works with 3G sticks.
I have the original "non-philly" Firmware. So the 3G stick should work... But nothing happens...
So maybe could it be a hardware problem? I'm not that familiar with the technical side of the usb port, so could it be damaged in a way, that the usb-keyboard works, but 3G stick would not???
And I just wanted to be thorough so I "installed" the update.img from the Arnova site, didn't help (well what would you expect when you install the same rom you already had).
So I'm thinking, if I install 1.5D ROM by Bob (which I'm going to do in some point), it won't help me with the 3G stick problem...
I'm not gonna ship the tablet to the shop yet... so NOW I have Finless 1.5D ROM installed... so how to get the tablet to connect to a AD HOC... I´ve created an ad hoc on my laptop (win XP) I found it, but when connecting it just says obtaining IP... so is this the wrong ROM (1.5D) Should I have the 1.5C?!?
Or is is possible to get internet connection trough the ARNOVA USB to PC cable?
I know this might be off topic, but I want to get an internet connection somehow...
