Problem is, every time I click on Settings, Language & input, Default - the system reboots itself. I have installed 5 different keyboards all with the same result.
If I knew which conf file(s) to change, I hopefully could change it manually.
I can only assume all users of this tab are experiencing the same issue and hope that someone knows which conf file I'm looking for.
Thanks a bunch.
Randy.
