Polaroid PMID920
Polaroid PMID920
Hello. I am pretty new to android and the rooting stuff. I was playing around with a Polaroid PMID920 tablet and I messed something up. I was trying to follow the guide at http://forum.xda-developers.com/show....php?t=2588991 and something I did made the apps stop opening. So I turned it off and back on, when it came back on it will only load to the recovery menu. (Default recovery menu) I tried to do a data wipe/factory reset from the recovery menu and that didn't help at all. It will only boot to recovery menu. If someone could tell me how to fix this I'd appreciate it.Tags: None
It took a while for the pmid701c firmware to be released on southerntelecom. All the Roms on this polaroid forum were decompiled from existing firmware using android kitchen, I believe, and not built from scratch! Email support fr your tablet until they release it.
There is another method used on other types of tablets that would do adb pull/push to create a nandroid backup of a reset device which could then be posted to reflash soft bricked tablets. Don't see that method has ever been used successfully on these.
sent by mirrorflash Morse code
There are currently 1941 users online. 1 members and 1940 guests.
