Help, need tun.ko
    Help, need tun.ko
    Good afternoon, I have this smartTV: http://www.ntech.pt/index.php/mini-pc/alexis-dx3060
    but it doesn't have the tun.ko module, I've tried several tun.ko files even with tunko installer from googleplay but I can't find a working module, the stick freezes and the it reboots. I need the module to run Ultimate servers pro(to run a VPN server on it), even openvpn connect freezes.
    I have a backup of my room that was made with CWMod recovery: https://meocloud.pt/link/0475fce6-df...ginal%204.1.1/ is it possible that someone could have the correct tun.ko for this firmware? Tanks
    Kernel version ?
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
      Originally posted by abdul_pt View Post
      Kernel version ?
      here is a photo:
        Try this ones
        You know what to do ?
          Using a terminal, and the command insmod right?
          Enviado do meu WT19i através de Tapatalk
            Don't forget to set permissions
            Chown 0:0
            Chmod 644
            Them if no error's raised check with lsmod
            Tapatalked
              it works!!!!!! tanks a lot
              Enviado do meu DX3060 através de Tapatalk
                Re: Help, need tun.ko
                Na boa.
                Tapatalked
                  é sempre bom ver alguem a falar pt por aqui
                    hey abdul.pt - any chance you can help me too?
                    I'm also looking for a tun.ko for my device -
                    http://www.netonnet.se/art/tv-och-bi...1/198722.1002/
                    Android-version
                    4.2.2
                    Kernel-version
                    3.0.36+
                    Mon Jan 13 11:47:51 HKT 2014
                    Version
                    ADS2.1_RK3066_Public_V422_131224
                    can you help me too?
                      Current WiFi Chip is MT5931
                      does that help?
                      Android-version
                      4.2.2
                      Kernel-version
                      3.0.36+
                      Version
                        Bump - a year later - I still can't use VPN... kind of frustrationg - the one that the tun.ko installer app downloads crashes / restarts my stick when trying to start a vpn. PLEASE HELP!
                          Try this ones - http://www.mediafire.com/download/st...s_3.0.36%2B.7z
                            that is a kernel w tun.ko included? how do I install that? cwm flashable?
                              and HUGE thanks for trying to help abdul_pt !
