M9 PRO 3G DUMP PROBLEM
    Hi, i don't no what's happenning but i try to dump with rockchip androidtool 2.1 under win7 x64 and it doesn't work. the loader is reconized and i do as habitually with my other rockchip device succefully. i've try both rock 3.0 and 3.70 driver version. And try different usb port back of pc direct on motherboard of course...
    i put 0 in start and 2 in count to get the parameter and got it succefully. try to dump system.img and get a 5ko file size.
    what's wrong ? hope someone could help me, i receive my m9pro 3g today and don't want to use it before a full factory state dump
    i got a new xfx motherboard last week, i uninstall win7 and re-install xp32bit on it and same thing, look :
ID:	439204Click image for larger version
ID:	439203Click image for larger version
    waiting for an answer, during this time i'll try my old p4 pc that i know it's working before to see...
    Thx
    no one ?
      bump
        does this work?
        I used it to extract the ROM from my M9Pro and insert a new parameter.
        Edited to fix link.
        Currently Inactive on Freaktab.com
        I use: MK903V | MELE F10 Deluxe | Roku 3600R
        RIP: MK808b | MK809III | PIPO M9 Pro
          Thx budgetgeek.
          i'll use it to backup my new mk908 this way due that Androidtool 2.1 work but give wrong size file like a 16 384ko system.img !!!
          do no what's wrong with this tool who was working very fine with my mk808b original but seem to be a no way for others devices....
            You can update the ini file to try to extract more, like the parameter file but probably not userdata.
