Recommended App Space Setting for running XBMC
    Hi guys what would you suggest using info below from Finless 2.1 Rom
    Choices:
    - You have 4 parameter files to choose from.
    You can optionally select a different parameter file to increase APP space over the 1GB I provide by default.
    BY DEFAULT IF YOU CHANGE NOTHING, 1GB parameter will be used.
    You have a choice of 1gb, 2gb, 4gb, 6gb.
    Note the more you give to APP install space the less you have available in Internal SDcard.
    the 6gb will leave you with only about 500mb of internal SDcard space.
    Usually I install about ten apps, with XBMC I generally install a hundred or more video addons with just about every Repo (Its Addictive)
    Looking forward to replies Ed
    Take the 1gb. XBMC saves most of its data on the internal storage, so it is better to choose a small app space and large internal storage if you are a heavy user of XBMC.
    Sent from my GT-I9100 using Tapatalk
      Looks like a detox for me as a heavy user
      Thanks for your advice much appreciated
      Ed
