You install lgcamera like a normal app.
Pipo M7 Pro RileyROM 2.8 KitKat
Re: Pipo M7 Pro RileyROM 2.8 KitKat
Originally posted by tabglo View PostIs there some given notice about modifications made by Edge Xuan?
I just prefer to make my own from the stock firmware, and not have to support problems or questions about another developer's work.
The only reason I tried the Edge Xuan ROM was that I pretty much had the ROM done before I realized it wasn't stock. Since I didn't have this version, yet...I just went with it. Of coarse giving him credit. I sort of like the UI changes he made.
When I finally received the stock version, I just updated the ROM with it.
Basically, its just another choice. I just like to give options. The users have the power to use whichever ROM they like.Randy
Actually not. I have two disc hernias in the lower lumbal vertebrae. So there will be a surgery soon after which i hopefully am able to move again without crying. If so then I'll be glad to provide some kernels. I got some more scripts for kernels but something seems to be wrong with that. Anyway, i am using the 1704 mhz cpu 720mhz ram kernel which brings 21100 antutu score. At least this one I'm gonna upload soon
Im also using cpu1704 and ddr720. I generated my own kernel patterned to giouncino's very low voltage kernel. Seems stable, no reboots yet after 12hrs.
If anyone wants to try here it is:
kernel_M7Pro281_cpu1704-verylow_gpu600_ddr720.zipProud M7Pro owner and Freaktab fan
Originally posted by MFinchy View Post@cshock2010, your kernel does not work on my Pipo M7 Pro Wifi. M7 continously reboot after flashing. I assume that the voltage is to low for my tablet.
if you're still willing to try, 1 have standard voltages and 1 with a bit higher voltage on the highest frequency.
kernel_M7Pro281_cpu1704-standard_gpu600_ddr720.zip
kernel_M7Pro281_cpu1704-high_gpu600_ddr720.zip
both worked on my tabProud M7Pro owner and Freaktab fan
I had the same problems with reboots. Now with a lower frequency kernel (1608mhz) the problems stopped.
I think the CPU in these kind of tablets work on the limit, cause pipo want to sell them as highest cpu clock tablets as possible. Some CPUs can take a little bit more of frequency, some not. Its like overclocking a desktop CPU. The CPUs differ in the same serial. If you want to overclock, the system isnt very stable anymore.
In my case, I dont need a tablet with a CPU that is as fast I can get it. I use it in most for internet and reading, not for heavy gaming. Just a little. Stability and battery life is more important. I naver had any speed problems with the lower clocked kernels.
hey folks, i use my short break from hospital stay before the surgery to provide my kernel
it is everything stock voltage with 1704 mhz cpu clock and 720 mhz ram clock
kernel_1704_ddr720.zip
it gave me 21100 points in antutu and 5600 in quadrant...
have fun with it
There are currently 1742 users online. 1 members and 1741 guests.
