and it works fine including the wifi & BT but it's a 720P kernel and is not over clocked, could anyone cook up a rom that could support the wifi and bluetooth, runs at 1080p and can be over clocked?
ROM request: for CS968/HX8-C/V04 Baord
I have one of the newer CS968 with a board number of HTC-T018-V4, I have used the rom at this link http://www.freaktab.com/showthread.php?10064-CR11S-CS968-(8188-Wifi-Works)-TV01-1080p-GT-19300-(G3-Spoofed)-2MP-5MP-6210-(Built-IN-NEW-Video-Mix-App)-quot-BeYond-XBMC-quot-READY
and it works fine including the wifi & BT but it's a 720P kernel and is not over clocked, could anyone cook up a rom that could support the wifi and bluetooth, runs at 1080p and can be over clocked?Tags: None
Originally posted by horvak View PostI have one of the newer CS968 with a board number of HTC-T018-V4, I have used the rom at this link http://www.freaktab.com/showthread.php?10064-CR11S-CS968-(8188-Wifi-Works)-TV01-1080p-GT-19300-(G3-Spoofed)-2MP-5MP-6210-(Built-IN-NEW-Video-Mix-App)-quot-BeYond-XBMC-quot-READY
1)You cannot overclock the latest CS968 because of locked RK3188T procesors.
2)To get 1920x1080, download terminal emulator from Play store, and type....
SU (press enter)
am display-size 1080x1920 (and press enter)
am display-density 240 (and press enter)
(then reboot!)
To go back to 720p, type.....
su
am display-density 160
(then reboot)
or type.....
SU
am display-density reset
am display-size reset
(reboot)
Never Buy The CS968
Why do you guys keep buying the CS968, you know before you purchase it, that it's a 720p device ... Then you want somebody to build you a 1080p ROM for it ... Ask the manufacturer to build you a 1080p ROM build for your CS9698 ...
Guys buy the CR11S, it's factory 1080p and 4K ready, get it HERE http://www.aliexpress.com/item/2013-...424683447.html ... A strong and simple solution ...!
Originally posted by Tech1 View PostWhy do you guys keep buying the CS968, you know before you purchase it, that it's a 720p device ... Then you want somebody to build you a 1080p ROM for it ... Ask the manufacturer to build you a 1080p ROM build for your CS9698 ...
There are currently 1894 users online. 0 members and 1894 guests.
