12) No matter what, reboot the PC now. Also unplug the NX and let it reboot13) Once the PC is back up plug in the NX and repeat the steps for getting into flash mode!
14) Now this is important! If you did everything right when you go into flash mode (blank screen),
the PC Flash tool should now say at the bottom "Found One LOADER Device"
If it does not, you did not get the drivers installed! repeat above yet again.
Flashing the ROM:
OK so you know how to get into flash mode AND you got the drivers installed.
The flash tool says at the bottom "Found RKAndroid Loader Rock Usb". We are ready!
***Once I am at step 14, the pc flash tool reads "Found one loader device," but I can't seem to get it to read, ""Found RKAndroid Loader Rock Usb." What am I doing wrong here?
