[ROM Download] Android 4.4 Kitkat Beta Firmware for Q7 rk3188-t quad core TV BOX
    Hi guys:
    As i have written in some days ago, rockchip release the android 4.4 SDK for their device. so i push differentfactory to working on the android 4.4 firmware. Today, i get the new beta firmware from Q7 factory. So Here we go:
    Firmware Download Link
    what works:
    Bluetooth
    RKremote control
    Miracast
    Sound Manager
    VPN
    Web camera
    etc.
    what’s missing?
    Google Play store
    If you want to try this beta firmware, please go ahead and download, welcome to report any bugs you found, we will push factory to solve.
    This beta firmware still 720p, and not rooted. but you can root it with this tool:
    http://www.mgyun.com/en/GetVRoot
    How to flash this firmware?
    download the flash tool here:
    http://www.mediafire.com/download/cm...hTool_v1.7.rar
    download the rockchip usb drivers here:
    http://www.mediafire.com/download/yq...ckusb_v3.5.rar
    and if you have problem to install drivers, you also can read instruction here:
    http://blog.geekbuying.com/index.php.../#.U0YzaFdw1B4
    DETAIL UPDATE INSTRUCTION, PLEASE VISIT HERE:
    http://blog.geekbuying.com/index.php...d-core-tv-box/
    Source from:
    Looking for developers
    Originally posted by geekbuying View Post
    Hi guys:
    what works:
    Bluetooth
    RKremote control
    Miracast
    Sound Manager
    VPN
    Web camera
    etc.
    what’s missing?
    Google Play store
    Source from:
    It's rubbish, don't bother downloading. Still has micro frame skipping issue and loses functionality over stock ROM. Basically you are making your box worse by using this ROM.
      Thanks. I'll try it.
        Ignored like a boss!
          kitkat 4.4 beta- what works
          Geekbuying...
          due to usuing purely as xbmc tv box, use of a bluetooth mouse/kb for me is a must as supplied remote is tedious to use.
          this beta has a single advantage over stock rom and Lewi's modded rom, but mainly is a lot worse.
          Bluetooth works properly for a start, my i-pazzport flymouse/board behaves as should (tethers but will not function on other roms)
          audio is pants...stock rom is ok and Lewi's work 's just fine..
          wifi keeps shutting itself down, randomly or disables itself.
          eth/wifi/bt all shutdown if box left running when not being used.
          have tried the art setup, but no apps work,
          Can't get vec's rom to load past the little guys in dinner suits.
          Any chance of pushing manufacturer to release either a stock rom with working bt or get an update for the beta with fixed audio/wifi.
            Hi guys:
            what works:
            Bluetooth
            RKremote control
            Miracast
            Sound Manager
            VPN
            Web camera
            etc.
            what’s missing?
            Google Play store
            Source from:
            I flashed myQ7 with your firmware, worked great except googleplay, as you stated so wanted to go back to JB4.2 but think I bricked it, keep saying " IDB failed" help
            Thanks see attached
              Hi How can revert back to JB4.2?
              Please help
                Help Geekbuying
                Hi guys:
                what works:
                Bluetooth
                RKremote control
                Miracast
                Sound Manager
                VPN
                Web camera
                etc.
                what’s missing?
                Google Play store
                Source from:
                I installed your firmware and tried to reflash back to 4.2, now I am stuck on flash mode, please help
                  You first have to erase your device with the KitKat parameter file then you can reflash a JB rom otherwise you will brick your device.
                    Thanks for you reply, but do you think geekbuying will ever reply, after all he is the developer!
                      Geekbuying is a reseller of Android boxes.
                      They don't develop firmware themselves, factories compile new firmware for them, so you won't get a reply.
                        How is this done? What tool should I use and where I can find right parameter file?
                          this is the v001 firmware
                          can get the v003 firmware here
