S802 device with WEB-Cam and MIC
    Hello,
    does anybody know about plans for a AML S802 box with cam and mic ?
    regards
    Frank
    Originally posted by sunfreak View Post
    Hello,
    regards
    Frank
    Till now no, maybe in future, yes, but the tronsmart vega s89 support usb webcamera, we test with logitech c170,it can work well.
    Eric
    Looking for developers
      @geekbuying
      many thanks for that fast answer - that's a valid option.
      How to get mic function?
      BTW:
      I am a bit confused about S802/S802DD/S802H...
      Does the tronsmart vega s89 handle DD and DTS passthrough via SPDIF/optical out?
      THX in advise
      Frank
        @geekbuying
        BTW:
        THX in advise
        Frank
        The vega does not support hardware DD or DTS passthrough. However, XBMC has the ability to do it in software and it works perfectly well. If you need passthrough in other apps then you may want to wait for a s802H device.
        Only after you've donated to Finless and Neomode are you allowed to donate here.
          Hello all and many thanks for the answers.
          I got still one question:
          As there are no planes for a S802H device with webcam and mic i am looking for external solutions.
          External webcam might work (according to Eric).
          Any ideas how to get a mic function?
          Frank
            Re: S802 device with WEB-Cam and MIC
            Frank
            I don't believe it works without new firmware giving us access to sound devices manager.
            Sent from my mobile device. Please excuse any typos.
