Which CS918 device do I have? (picture inside)
    Hi, I have the CS918, could you tell me which one it is?
    or how can I find out which Version I have?
    This are the Details of my Android TV Box CS918
    Model rk31sdk
    Android 4.2.2
    Kernel Version
    3.0.36+
    arron@develop-server #201
    Build-Number
    rk31sdk-user 4.2.2 JQD39 user.arron.20140308.151002 test-key
    Vendor software version
    RK3188_R-Box_Android4.2.2-SDK_V1.0.0_120514
    RK3288 Devices
    - Overview BOX (LINK !)
      Hey,
      You have the same as mine:
      I think it is a non standard CS918, at least it doesn't match the CS918 according to this post: http://blog.geekbuying.com/index.php...d-core-tv-box/
      Couldn't find any custom firmware for it. Anyway, it seems to be working fine in terms of Video, Audio, BT and Wifi. I do have some issues when streaming (Direct Play) from Plex, like a small 0.1s pause every 10 seconds... but it doesn't happen all the time.
      I'm connected using Ethernet, where the bandwidth shouldn't be a problem. I'll try to do some tests playing the media locally, to take off from the equation my Plex server and network switch.
      Cheers!
        Can anybody Help?
