I use now mplayer on my x7.
but when i'm streaming some content to the minix that's on 1440*1080p50
the player is a bit slow, especialy on sport's when you have all the player's moving arround
it does not show like the pc where this problems dosen't happend.
Could it be the deinterlacing on the minix that isn't active?
This is the type of strem that i try to whatch.
Format : Matroska
Format version : Version 2
File size : 4.73 GiB
Duration : 1h 52mn
Overall bit rate : 6 031 Kbps
Writing application : Lavf54.63.104
Writing library : Lavf54.63.104
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=24
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 5 783 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 50.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : A_MPEG/L2
Codec ID/Hint : MP2
Duration : 1h 52mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 23ms
Stream size : 103 MiB (2%)
Language : unknown
Default : Yes
Forced : No
