MK902 + AIR MOUSE MEASY RC11
    Hello,
    my MK902 has arrived
    All is working fine, but my air mouse Measy RC11 does not work with the MK902
    (instead it worked with the old tv box i had (T-R42))
    It simply is not seen by the MK902...when i insert the dongle in the usb port of the MK902, does not happen anything...
    Instead when i insert a normal wireless dongle for keyboard + mouse (e.g a Trust wireless keyboad + Mouse)
    the dongle is seen by the MK902 and it works...
    Do you know if there is any way to enable the RC11 for my tv box?
    Thanks!
    I have mk902 and Measy RC11 and it works out of box flawlessly (as well as my Logitech K400). The mouse cursor has tendency to continuously move down (stupid servo) not comparable with Wii remote but it's usable and working.
    I use Neomode 1.9a.
      Originally posted by tobr View Post
      I use Neomode 1.9a.
      Thank you,
      so i have to install neomode 1.9a
      I have also need to root my mk902 because i have to install a vnc server on it.
      Did you check if it was working when you had the original stock rom?
      Thank you!
        Hi, unfortunately not. I have bought measy rc11 after I stopped changing roms 3 months ago. Everything I use, is working quite fine so I am not pushed into any rom change at the moment.
          thanks,
          so perhaps there is something in my measy rc11 that does not work...
          this is strange because i tried it connecting the dongle to an usb port of my windows pc,
          and it works (the pc has automatically installed the needed drivers)
          instead with the mk902 it doesn't work, seems the dongle is not seen by the device
          but i checked that my mk902 works with a 'standard' (Trust) wireless mouse + keyboard dongle
          perhaps i have to reinitialize the rc11... i dont know what i have to do
          any suggestion?
            i have just a question:
            do you see any message when you insert the rc11 dongle in the usb port of the mk902 ?
            a user told me that he had problems with wifi, that was interfering with the rc11 wifi signal...
            do you use wifi?
            thank you
              No, I use cable lan. But yesterday I tested without cable on wifi for you and everything was ok. Android, xbmc and measy rc11 working like charm.
              If I remove/insert a dongle while running, rc11 is working again a can't see any message. But I didn't look into dmesg.
                Ok thank you!
                Yes, i can confirm that now it works also for me...:
                i tried to insert the rc11 dongle on other usb ports (i have put it in a usb port on the other side of the tv box, where is not written usb slave), and tried to reinitialize the air mouse, and now it works...
                Thank you!
