Tronsmart Vega S89 questions.
    Let me start by saying I started monkeying around with the original xbox modded to run xbmc to watch movies. I was blown away with the performance at the time and thought life could not get much better.
    Then HD movies hit the scene and my poor old xbox could limp on some 720 content and i needed something new to stream local content.
    In came the boxee box and i know a lot of xbmc purists knocked it about and mocked it but for me it played everything i could throw at it. Other than the hdmi passthrough issues it performed what i needed most.
    Now the old boxee bricked on me and im at a loss for the last 3 years of new setop boxes and now android boxes.
    Im considering the Tronsmart vega s89 to run xbmc on the specs look reasonable for the price point but will this device utilize the hardware acceleration in the new builds of xbmc?
    I keep waiting for reviews and forum posts about the vega s89 perhaps there is something similar in specs around the same price point that has been tested and used successfully.
    Should i hang in there and wait for more info to surface about this device or can someone make some recommendations i could also consider?
    received my tronsmart vega s89 from geekbuying the other day, so far so good but their is a bit of issue with regards to xbmc most of the adds on is incompatible but so far manage to watch with icefilms and mash up
      How is xbmc running for you otherwise any problems with video or audio?
      The streaming online apps are secondary for me its the local content that is important.
        Please tell me , do movies stream smooth or do they have the micro frameskip issue ?
        Im thinking of buying one too.
        thnx
