thanks
KitKat for CS968
KitKat for CS968
Here is the link for the 4.4.2 rom for the CS968 https://www.dropbox.com/sh/uwhgr3lnhjrjzq4/Fu0tfcWHeh. This rom is not rooted and it is 720p, not 1080p. So far it seems very stable. It does not sync my calendar with my google accounts, which I miss. Same for contacts, not sync'd. The latest XBMC does not passthrough Dolby Digital, but other players do. If someone can point me in the direction on how to root kitkat, I would appreciate it.
thanks
MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68Tags: None
Originally posted by clarkss12 View PostHere is the link for the 4.4.2 rom for the CS968 https://www.dropbox.com/sh/uwhgr3lnhjrjzq4/Fu0tfcWHeh. This rom is not rooted and it is 720p, not 1080p. So far it seems very stable. It does not sync my calendar with my google accounts, which I miss. Same for contacts, not sync'd. The latest XBMC does not passthrough Dolby Digital, but other players do. If someone can point me in the direction on how to root kitkat, I would appreciate it.
thanks
[ATTACH=CONFIG]6176[/ATTACH][ATTACH=CONFIG]6177[/ATTACH]
Bob made a (root zip) its on hear some where I will post it hear if I can find it
Found it, the link is in post 2 thanks to bob its made for the x7 but should work
Originally posted by blinkone View PostBob made a (root zip) its on hear some where I will post it hear if I can find it
http://www.freaktab.com/showthread.p...light=root+zipMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostThanks, but said it was not a valid package. Open to other ideas. BTW,this is a very stable rom, not a single reboot or freeze.
im very tempted to try ths rom out my self on my cx919Please consider making a Donation to freakTab
Originally posted by blinkone View PostThat's strange its worked for a few other sticks you could try this
im very tempted to try ths rom out my self on my cx919MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostTried installing that program on my windows 7 machine, but my antivirus software would not allow it. It showed 2 virus and would not let me bypass them.Please consider making a Donation to freakTab
Originally posted by blinkone View PostTry this one http://www.mgyun.com/en/GetVRoot
Thanks, for trying.... I appreciate any help I can get.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostOk, tried this program and it installed ok. On my device, I turned on "connect to PC" and had the correct settings in debug mode. Disconnected device from tv and connected to computer. Vroot still could not detect device. Tried different usb ports on the device and computer, still not detected. Just for the heck of it, I thought I would try my older LG smart phone. Set up usb debug settings and connected to computer. VRoot found the phone and did it's thing and when it was complete, the program said my phone had "root". To verify that my phone indeed had root, I downloaded root checker. when I ran the root checker, it said my phone did NOT have root. Soo, I can conclude that VRoot does not work on some devices, at least not mine.
and
Note, it's different from how to install ROM, in this (Rooting) you need power supply, keep the tv and pc nearby to see if device rebooting, (i click the .bat command after i click "connect to pc"), before pressing "space bar", again click "connect to pc" then follow the instruction..,
There are currently 2181 users online. 1 members and 2180 guests.
