(MK808B clone) powered hub problem
Hi I just bought a 7 port powered hub (http://www.newegg.com/Product/Produc...9SIA2PY1GA0524). If the hub is powered on and connected, it won't let my MK808B boot. Could it be over powering my MK808B, it seems to work fine if I power it up after it boots. I tried to cover the power contacts on the usb cable but it won't recognize the hub or anything attached to it. Does anyone know how to fix this.Tags: None
Originally posted by phinc View PostHave you tried both USB slots (OTG and the normal one)?
Sent from my GT-I9100 using Tapatalk
Right now I'm using the hub without the ac adapter, with only my external hard drive and xbox dongle attached. I wanted to add a wireless keyboard and a usb lan adapter but I'm going to need the hub to be self powered.
[QUOTE=DannyCalifornia;166915]Hi I just bought a 7 port powered hub (http://www.newegg.com/Product/Produc...9SIA2PY1GA0524). If the hub is powered on and connected, it won't let my MK808B boot. Could it be over powering my MK808B, it seems to work fine if I power it up after it boots. I tried to cover the power contacts on the usb cable but it won't recognize the hub or anything attached to it. Does anyone know how to fix this.[/QUOTE
I've got the same issue...
First, Plug it in the host port, but only after you plug the power supply of your tv box and until is begin to start.
It's because the hub power supply have only 1A and is not enough to start well.
Give news!Bonjour! Je suis de Shawinigan, Québec, Canada
Originally posted by DannyCalifornia View PostThanks, I added an on/off switch to the powered hub. I'm planning on doing a case mod soon. I'm still waiting for some things I ordered to arrive in the mail, hopefully I'll be done by Friday.
This was the link
http://www.****.co.uk/itm/181397573292
It seems rather expensive at £9.98 or $16.85 US Dollar
Has anyone tried a cheaper cloned variety adapter that matches those speeds seen on the video?
There are currently 1434 users online. 2 members and 1432 guests.
