Neomode Custom Rom MK802IV Old Wifi Version 3.0 Android 4.4.2 FullHD
    Originally posted by hanskie View Post
    neomode, what about version for MK802IV with new wifi AP6210? Could you prepare this for us ?
    +1
      same as MK809III version 3.1
      Lol? Isn't that exactly what the MK809III version listed below this one would be? Minus saying 'MK802IV' under device info? It is compiled for the AP WiFi.
      Here.
      Regards,
      Jack
        Tested with other kernel?????
        Has anyone test it with the old kernels?
        Please report if someone do this.
          Originally posted by chtheo View Post
          I do not believe they will work, as they were not compiled for KitKat.
            Re: Neomode Custom Rom MK802IV Old Wifi Version 3.0 Android 4.4.2 FullHD
            JellyBean and KitKat kernels are not cross-compatible. Stay with KK kernels for 4.4.2 builds, and only match "beta" kernels with beta KK rom builds.
            Sent from my SGH-I337M using Tapatalk
            Please post your h/w & s/w as signature to help community with troubleshooting problems.
            Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
            uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
            iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
            Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
              kernel supports?
              Hello I have ITaSee IT808 which should be identical to CX-921, wifi should be 8188. I flashed it as I can flash Ugoos UT1 firmwares. But wifi can only work if I change the kernel supporting a RTL 8188. Other than that browsers crash I don't know why
                I will try this kernel for rtl8188 : http://www.freak-tab.de/d33/kernel_KK_v4.20_TVSTICK.zip
                kernel_KK_v4.20_TVSTICK_RTL8188_HD.img
                Anyone who has try it??? The file is bigger than Neomodes.... 8,29 MB -- 10,3 MB
                  What is the last update on that kernel? A few weeks ago I tried it and had the same freezing problems after a restart. Haven't checked there lately though.
                  Regards,
                    Newer
                    Regards,
                    25/5/2014 is the date. I think is newer...Neomodes is 13/4/2014.
                    I think I will try it
                      Yes, that is more recent than the version I tried. Please let us know how it works.
                        I doesn't work! I have just bricked my 802IV
                        I doesn't boot at all and my MK802IV probably is DEAD. I tried to reinstall the 1.5 version of Neomodes but the switch on the board it doesn't work. I took it off theboard , I made a shortcircuit but NOTHING. I used a niddle to shortcircuit the 7 and 8 pin of NAND , IT WORKED BUT THERE IS ALWAYS AN ERROR TRYING TO ERASE IDB OR FLASH. The device is working in MUSK MODE when using the niddle.
                        I tried also and original Rikomagic software but when trying to flash there is an error.
                        ANY IDEAS???? OR move it to the recycle bin
                          No no, I'm sure it is not dead. I know one of the older flashers (pre 1.5) had the 'switch' button to change flash mode in the utility. Perhaps give that a try?
                          Regards,
                            Failure....
                            No no, I'm sure it is not dead. I know one of the older flashers (pre 1.5) had the 'switch' button to change flash mode in the utility. Perhaps give that a try? Regards,
                            I have tried several versions of flashers and Android tools 2.1 . None of them can erase IDB ,switch or flash in maskrom. May I have to find another way to activate the stick on PC . Now I use a niddle and make a short circuit between 7 and 8pins of nand. Do you have any specific program to try?
                              Did you just overwrite the kernel when you flashed, or did you do a complete reflash of the device? Flashing just the kernel could not kill a stick like this. What bootloader version did you flash?
                              My process for flashing is as follows:
                              -disconnect all power and usb from all ports (OTG and power port)
                              -plug USB into otg port but not computer
                              -push button in (in your case short)
                              -plug USB into computer (while shorting) (computer will provide power through OTG port)
                              -keep shorting for a few seconds
                              -remove short
                              -device should show up in flash utility (and be flashable).
                              I had the problem you're having now a long time ago (when flashing neo 1.5)
                              No worries, it'll come back.
                              Regards,
                                -remove short
                                Regards,
                                unfortunately I did all theese steps at the first phase.
                                I made a shortcircuit even with soldel gun!!!!!!!! nothing
                                My only solution is short circuit pin 7 and 8 on NAND chip but it seems NAND chip has problem, when trying to EraseIdb the error is ERROR: Download boot failed....
                                I will keep try for a while....
                                NO MORE RK CHIPSET FOR ME AGAIN.....
