Can't wait to flash your rom tonight
Tronsmart S89 Elite Finless 1.2 ROM
I flash your rom but it's blocked the boot animation.
So i decided to follow the install option 2 but i can't find the reset button.
Is that possible?
EDIT: ok i find the reset button, i boot in recovery, install from EXT and stuck in boot loading again...
I'm trying 1.3 beta now...
UPDATE: rom 1.3 is just perfect
Thanks for your hard workLast edited by manux7; 05-08-2014, 10:16.
Originally posted by Saris View Postwhen playing asphalt 8 the device (elite version) reboots after few minutes of racing. it's possible that the issue is related to 1.2 ROM version itself or it's a hardware fault?
In answer to your question, your box is likely overheating try 1.5 first and see if that helps
need help. sorry if this is not the right place. need help
I bought my Vega elite 1 month ago. In the past week my apps stopped responding ( Google play, gmail, maps, Netflix, everything) I did factory resets and updates trying to just get the thing working properly. No dice. Then today it just won't boot at all. Stuck at the box logo. Its making the shiny looking animation but nothing else. I can't figure out how to get this thing into boot menu so I can flash the ROM or root it or do something with it. Maybe I'm missing something but I bought it to outperform my note 2 and my Asus memo pad 7. Its starting to be a pain. Will going with the finless ROM and instructions solve my problems? Sorry. This is my first time I had to post anything.
If it don't boot up (also to recovery) I think you have to use the OTG flash method with an img file ('USB Burning Tool with windows PC') but only works at win7 and less (not at win8)...
Wybierz Głośniki Bluetooth, Głośniki Przenośne i Głośniki bezprzewodowe dostępne w sklepie tronsmart.eu
Eric is actually uploading also an 104k4 img ...
Hi guys: Here is the newest stock firmware for Tronsmart Vega S89 series, version number is 104k4, why 104k4? the last stock firmware is 102k4, factory give me a 103k4 to fix the bugs you are talking, and then i find google play store show no connection problem in 103k4, and amlogic also release some […]RK3288 Devices
- Overview BOX (LINK !)
Newbie - Tronsmart Vega S89 Elite
Hi there,
I just bought a new Tronsmart Vega S89Elite, to my knowledge it works alright. I havent done anything to it, but my question to all you experts are. What should I do to my new wonderful machine? If anybody has a step by step guide I would really appreciate it. My purpose of buying it is to use it with XBMC to my tv and stream movies from my Syno NAS (DS214play)
As you know, XBMC is preinstalled on the machine, but one thing that is not working great for me, is when I add my NAS to XBMC then I don’t get any metadata for my movies, I only get the path of the movies. That’s not correct right? The reason I bought this machine were to get that metadata with my movies and be able to read about the movies, posters and such.
I hope that someone will give me a few pointers in the right direction. As I read this post it seems like I have to do some kind of installation (Finless) what is that and why do I need to install that?
Kind regards
GizmoDK
There are currently 2901 users online. 3 members and 2898 guests.
