Only difference I could see to get one ROM working on another is the wifi files!
Basically the kernel is different and the wifi files! A few other things also but nothing I see major.
However the interesting part is standard kernel runs FINE on the Elite version!
I want to do a test for you folks testing DTS and audio across the different chips.
What if I could fake the Elite into doing what the standard does?
So what I am looking for is someone with an Elite that knows how to test DTS and pass through etc.
I would want you to flash the standard ROM on your elite then I will give you a patch ZIP update to fix your wifi.
Who is willing?
