To confirm before purchasing PIPO M9PRO 3G
    Hi dear friends,
    i am a newbie on this forum. after so much research i have decided to purchase PIPO M9PRO 3G which meets my criteria. before finalising it i have few doubts on this product, which is why i am here in this firum.
    1)does it work with external dac connected via usb (i am always into music.i tend to use this tab as a music source too)
    2)what is the real world duration for battery efficiancy
    3)when connected to tv via hdmi, does it output sound too to tv
    hope i will get the answers soon
    Reply
    Not sure what DAC is, googled it and I get "Digital-to-Analog Converter" The device has 3.5mm audio jack, HDMI mini, USB and USB OTG ports. USB will power my bluetooth dongle, not sure if anything larger will work.
    Six hours, with wifi and continuous use. More without screen on.
    Yes.
    Currently Inactive on Freaktab.com
    I use: MK903V | MELE F10 Deluxe | Roku 3600R
    RIP: MK808b | MK809III | PIPO M9 Pro
      1) dac
      Haven't tested it, snce I don't have one.
      But I can say that I can mount a usb stick succesfully
      I can't however access an external usb drive, since it draws to much energy from the usb port (these drives even came delivered with cables to connect to two usb ports to get energy, so this seems quite normal)
      I could connct my tv usb connector, it lights up, so it start, but lacking software to manage it ...
      So if that dac is a small device and it comes with support for android, I would think it will work.
        out of curiousity, tested a standard usb audio key;
        as I allready mentioned, de audio dac lights up, but it cannot be used since there is no software/driver available. You need to make sure your dac has support and software to work with android.
