Does anybody have an appropriate cifs.ko module, which should load with insmod through terminal app? I really want to mount a network share with CIFSManager on my CS918S. Help is highly appreciated.
cifs.ko for CS918S
Originally posted by TaajanThere is a group that is working on the CS918S, but right now, we are trying to get true 1080p to work and stick. Right now 1080p@24 is the only one that works, but then switches back when you restart the tV. If you could assist that would be awesome, also it would help out a lot for all of us to help research and get the file that your looking for to work on our devices. Now a question for you. Is the cifs.ko, is that like a driver? Thanks
1. I'll mount shared folders from my window server.
2. After mount I can use shared folders like internal directories. This means that I can use mx player when internet streaming playback in my xbmc.
this is just an theory.
I tried install cifs.ko module into my CS918S with this file but I can't success.
when I tried install cifs.ko module into my CS918S with this file. I can't make it. The result is right below
root@android:/data/data/berserker.android.apps.sshdroid/home/modules # insmod cifs.ko
insmod: can't insert 'cifs.ko': invalid module format
In the dmesg
[96846.109992] cifs: version magic '3.1.10-g05b777c SMP preempt mod_unload ARMv7 ' should be '3.3.0 SMP preempt mod_unload ARMv7 p2v8 '
this means the cifs.ko file is build for kernel 3.1.10 but CS918S is 3.3.0. I think this module isn't for CS918S
So I need cifs.ko module which is built for kernel 3.3.0
There are currently 1711 users online. 0 members and 1711 guests.
