I have 1280x800 screen, and would like to connect MK808B, is there a way to do it?
MK808B 1280x800 resolution
Originally posted by phinc View PostHave you tried it and it didn't work or do you want to know if it is theoretically possible?
Anyways, it will work if your monitor can handle a 720p signal, otherwise it will not.
It works with 720p, but picture is with not right proportion. It shows as "egg".
Originally posted by phinc View PostI don't know, depends on your monitor. Doesn't it have some kind of OSD to adjust brightness, contrast etc.? There it should have an aspect ratio or screen scale option or something like that.
Sent from my GT-I9100 using Tapatalk
There are currently 2611 users online. 1 members and 2610 guests.
