As the title suggests my 10g2 is stuck in an endless boot cycle.
It started as I was using an app, the system rebooted on it's own and since then it's stuck! I get the 'Freaktab.com' logo, then the static boot screen, then the animated one then it reboots and off we go again.
I've connected to my home PC and run ADB (power cable was not in) - eventually booted up after a long while. I noticed the battery indicator had a red cross, when I plugged in the power I ended up with an infinite reboot - this time never getting past the 'FreakTab' logo.
Rockchip loader detects it fine and the tab doesn't turn off so don't think it's a genuine battery issue.
Any ideas?
I'm going to try a re-flash of 2.0a I think - there are other people who've had battery issues so may be related (http://www.freaktab.com/showthread.p...ll=1#post15118)
Running FInless 2.0a with CWM
