Need help installing custom kernel
    Feel a bit of a fool here
    I have flashed many devices using various tools like cwm twrp using zip format, but installing one of bob's roms for the A928 (mine is mk908ii) i needed to install one of d33's kernels but i am lost !!
    Rom is installed but no wifi, how does one install just a kernel ???
    There are two main app for flash:
    Batchtool witch flash file containning all need files (zip)
    Flashtool witch flash file independably (.img + parameter etc)
    In flashtool select only kernel (mark box left) and select the desire file with the right ... box (kernel.img)
    T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
      Cheers sussed it now
