MK818B Crashes!!!
    MK818B Crashes!!!
    Hi
    I have an MK818b, installed with the latest firmware (update_mk818_307j2207).
    Whenever I get past the Google play and Android screens and start using the software, it crashes to a black screen and i need to hard reset the hardware to get it to load again. Once loaded, it crashes again when I use the software. I though first that it may be a firmware issue, so I upgraded to the latest version but still having the same issue.
    Please help as don't know what else I can do. Not sure whether the software or hardware is at fault.
    Thanks in advance
    (Mk818b) the market app might be broken, are there custom firmware for your device?
    Are you having problems with any other Google apps, like Gmail app?
      Stops Loading
      As I switch it on the Google Tv shows up and after the Android logo shows it's loading and it stops. It's got the latest firmware (update_mk818_307j2207) and brand new not even used it once.
        Try using a high quality power adapter instead of the one that came with your device(I'm using the one from my Google nexus7) . Try to re-download the file and use a different cable to flash your device.
          Sometimes it takes a couple of trys for the firmware update to take.
