Sound Devices Manager for CS968
I'm using SPDIF output to connect CS968(clone) box(android 4.2.2) to my audio receiver. So I select ROCKCHIP-SPDIF in the Sound Devices Manager and then there is output through SPDIF(optical). However if the device is powered OFF any time, the sound device setting reverts back to the default setting(analog audio) and there is no output through SPDIF. Again I have to set SPDIF in the Sound Device Manager and it lasts only till next power OFF.. Would be grateful if someone can suggest a solution.
Tags: None
Originally posted by reemster0180 View PostYeah I had the same. Did some research but it was a dead end. Yesterday I installed the kitkat non rooted release for v3 and the problem is solved.
Sent from my SM-N9005 using TapatalkLast edited by ntj8; 01 May 2014, 13:47.
There are currently 2761 users online. 1 members and 2760 guests.
