Tronsmart S89 Standard
The first lot was only S802 (Standard and Elite) and I think (but only think) the next lot (Standard) will have the same...RK3288 Devices
- Overview BOX (LINK !)
You mean minix x8s? That's the only known device at the moment, which will have the S802-H (maybe at end of Mai)...
BTW:
XBMC does software decoding and pass-through audio works perfectly for Dolby-Digital 5.1 and DTS 5.1 (MX Player will not do pass-through on this chip)
HI Guys: We get the first bulk of Tronsmart vega s89 in stock,and finish this passthrough review. Here is my test device: 1 Tronsmart vega s89 quad core tv box; 2 Yamaha RX-375 5.1 Receiver 3 Yamaha NS-P40 Speaker I test different 1080p mkv, ts format local video file, and use built-in XBMC to play […]
1 Dolby (AC3) 5.1 HDMI passthrough ——–OK
2 DTS 5.1 HDMI passthrough——-OK
3 DTS-HD HRA 5.1HDMI passthrough—–OK
4 DTS-HD MA 5.1 HDMI passthrough—OK
5 Dolby True-HD 5.1 HDMI Passthrough—can’t work, reciver just show 2.1, not 5.1
So, seems the HDMI pass-through is working ok, but there is something problem with optical pass-through (noise). I have reported this problem to factory, and check if they can fix it.
Update!
Just find in the optical pass through test, the noise is coming from the TV.
If i make the TV mute, and the sound will be ok, no any noise anymore.RK3288 Devices
Re: Tronsmart S89 Standard
Originally posted by bigall123 View Postthanks, i did mean the minix x8s. i hope there is a simple method to root the vaga, id hate to bick it out of the box. lol
Sent from my mobile device. Please excuse any typos.
There are currently 2193 users online. 5 members and 2188 guests.
