Apos Instalar o app chainfire 3d o mk808b travou no inicializar alguem me ajuda
    mk808b bought one and did the root, to install Chainfire 3d app and restarted the machine was in the boot screen, I tried installing the latest firmware even installing nothing on TV, do not know how to find the right version to install on Mk808b.
    comprei um mk808b e fiz o root, ao instalar o app chainfire 3d o aparelho reiniciou e ficou na tela de inicializar, eu tentei instalar o firmware mais mesmo instalando não aparece nada na tv, não sei como achar a versão certa para instalar no Mk808b.
    I do not speak English, but they can answer in English
    I think you should use google translate to post and you also should think of reading the notes of the app's you install.
    Usa o google translate para escrever e posta a tradução e o original.
    Flash com uma rom.
    Tapatalked
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
      Chainfire 3D is not working on Android versions above 2.3.
      Open up the case of your stick and show us pictures of the inside. Then we can probably tell you which firmware you have to flash.
      Sent from my GT-I9100 using Tapatalk
        I do not know the proper version for my device (mk808b) I already tried some more nothing on tv, can someone show me a tutorial step by step to reinstall the firmware?
          Flash com uma rom.
          Tapatalked
          pelo que puder você e de Portugal teria seu facebook para me ajudar eu sou novato em android tv?
