Make sure your device is set to debugging mode under settings/development and plug in to usb
1) in a command window with adb access type (make sure you have a temp directory in c
adb pull /system/bin/wpa_supplicant c:\temp
adb pull /system/etc/wifi/wpa_supplicant.conf c:\temp
2) just attach the two files and post here PLEASE!, after updating to firmware on southerntelecom website I lost access to my adhoc wifi.
THANKS~!
