NEW - CX921B - wasser firmware 1.0.3 - Kikat Android 4.4.2
    version 1.0.3
    - based on kikat 4.4.2
    - built from sources
    - perfect 1080p fullhd video streaming
    - multiuser support
    - preload wasser xbmc-1.1 based on gotham 13.1 stable release
    - passthrough support in wasser xbmc
    - busybox
    up to date
    - google apps up to date
    - screen rotation support
    - reboot/sleep/bootloader mode dialog
    - full support stock ir remote
    - lock screen support
    - init.d support
    - A2 Airmouse support
    - cwm recovery support
    - ntfs, nfs, cifs, hfsplusfilesystem support
    - rooted
    - usb webcam support
    - wifi support
    - ethernet support
    - bluetooth support
    - enable tun in the kernel
    - add setting for Accessibility
    - add setting for sleep, daydream and wallpaper
    - add support for Mouse Wheel Zoom Settings
    - add support for no wakup on mouse movement, enable it by default
    - add manual hide system bar, you can wipe from bottom/top of screen to show it again
    - add setting for Alarm/Notifications volume
    - add support hls streaming
    - fixed red frame issue in chrome browser
    - added option to disable the hardware keyboard (add ro.hardkeyboard.support=false to
    /system/build.prop to disable hardware keyboard )
    - several fixes which i don't remember
    firmware for new revision: wasser-firmware-cx921b-1.0.3.zip
    please use RKBatchTool to flash the new firmware
    version 0.95
    - kikat 4.4.2
    - multi usb partitions support
    - sound device manager
    - wifi support
    - ethernet support
    - bluetooth support
    - ir-remote support
    - init.d support
    - rooted
    - ntfs, nfs, iso, cifs filesystem support
    - preinstall es file manager, terminal
    - remove google searchbar
    - cwm recovery
    - add screen rotation
    - add notification sound
    - add lock screen
    - update busybox
    - add hardware keyboard
    - added 1080p24hz, 1080p30hz
    Link download: wasser-firmware-cx921b-0.95.zip
    Be aware: it is your own risk!
    Originally posted by wasser View Post
    version 0.95
    - kikat 4.4.2
    - wifi support
    - ethernet support
    - bluetooth support
    - ir-remote support
    - init.d support
    - rooted
    - cwm recovery
    - add lock screen
    - update busybox
    Can u make a kennel with support for 8188 WiFi module
      Problems with Google Account and Play-Store
      Hello,
      thanks for this great rom. Seems the everything works fine. I have one problem. I can't sync with my google account and play store can't connect.
      Anny Ideas.
      Thanks in advanced
        Originally posted by Krapfenheld View Post
        Hello,
        Anny Ideas.
        Thanks in advanced
        it works for me. It could be that your time setting is not correct and it could cause such problem. Please go to Setting->Date & time and set it correct.
        wasser
          wasser
          The network time was wrong. I changed the timezone, now it works fine.
          Thank's for your fast response.
            vox now
            Is it possible to make a Firmware to run VOX now ?
              what is VOX?
                what is VOX?
                I can Start this App using cyndia cubstrate and root cloak. But it plays only the live stream not the videos.
                I think the firmware has to be not rooted with a locked bootloader and should be recognised as a main stream tab like nexus 10.
                Ist this possible?
                  Thanks for the ROM Wasser testing it out now
                  I would love to work with you more on the this project. I will let you know how well this one works out.
                    https://play.google.com/store/apps/d...ractive.voxnow
                    Ist this possible?
                    it's possible you can spoof it as nexus 10, it's in /system/build.prop
                      feedbacks are always welcome!
                        Im having good success with this one and installed the TWRP. The original remote does not work is there ir codes the device has that we can add to a universal remote? Are the internal IR codes working i should say?
                          wasser firmware 1.0.3 is released for CX921B
                          Hi all,
                          wasser firmware 1.0.3 is released.
                          Enjoy!
                          wasser
                            Hi all,
                            Enjoy!
                            wasser
                            Hey Wasser, sounds amazing!! Hopefully everything will work and there is no need to waste my time with building a really working android xbmc rom with audio passthrough...
                            I will test it and report back. Thanks for your time.
                            By the way. Can you please build exact this kernel for rtl8188eu wifi and working ethernet on cx921a? Should be the same sound, wifi and ethernet config like ut1. But stock remote is the same like cx921b.
                            All the best
                            walter77
                            Donations are welcome and will be shared with other devs:
                            DONATIONS
                            CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
                              All the best
                              walter77
                              Hi Walter,
                              i don't have the stock ir remote so i cannot test it. It would be great if you could test the ir-remote if it works and let me know before i start to work on kernel for cx921a
                              thanks
                              wasser
