I have the following setup:
My neo X7 is connected with HDMI to the TV. The TV is connected to a Samsung sound-bar using optical wire.
In android sounds devices I have 6 options:
- RK29_RT5616 - which works but seems to be analog.
- ROCKCHIP-SPDIF - which does not work - there are no clicking sounds of android.
- RK29_RT5616 & ROCKCHIP-SPDIF - works ok.
- ROCKCHIP-SPDIF PASSTHROUGH - does not work (no clicking sounds either).
- RK29_RT5616 PASSTHROUGH - works and seems to provide better sounds.
In XBMC I have only two options:
- Analog - and then all the options of DTS,AAC and AC3 are disabled.
- Optical/Coax - which I chose.
What should I choose for my setup if I would like to enjoy surround(ish) sound experience with DTS and Dolby Digital 5.1 videos (I know it will be downgraded to 2.0 - but still the sound is fuller and richer).
thanks.
